SOURCE: canon iP1900 paper jam error
Use this Ip Tool,
Reset your printer.
First:Find the model on the tab, then reset the black and color,after that reset the platen and main, and finally reset the EEPROM.
Hope it works!!!
SOURCE: Canon i560 prints a black smudge pattern on left side of page
There must be some small piece of paper or paper dust buildup near the left side of the paper feed/press mechanism under the printheads.
Open the cover and inspect the far left area along the line of head travel - there often is a metal plate with small wheels that stabilize the paper, and under that plate look for some foreign objects. Try gently removing them with a toothpick - it is soft enough not to cause any damage, and also will soak in any ink residue that might be left there.
SOURCE: my canon ip1900 printer does not print even though
Your printer cartridges have likely dried up. You can try removing the print cartridges from the printer and pressing the print head (the bottom where ink comes out) into a moistened paper towel. This will hopefully rehydrate the dried ink in the print nozzle. Ink will likely transfer onto and through the paper towel, so please take precautions to not soil anything.
If this does not work you will likely need new printer cartridges. Refills can be used with decent success for the black but the machine will likely refuse a refilled color. Unfortunately this is how Canon has designed the machine. An original should be used in this instance.
SOURCE: I have a canon ir3100cn. smudging problem
Does the toner seem like it isnt "baked" enough?
If yes replace fixing assy.
SOURCE: What does a flashing orange
your cartridge or cartridge carier has problem
open printer door, check cartridge, if cartridge ok, close printer door then
press orange light button for more that 2 minute, for me it always work
i hope this helpful
thank you for using fixya
