When battery is inserted in set it becomes very hot in very short time like 15 minutes. more over charing is indicated by battery but battery does not charge.
Pratap, it sounds me water damage problem,if you are not Technitian dont try this please.give some oficial repairer.this is a hardware problem and probably problem is with PA Network IC or/and Avilma, 1.First clean board with Alcool2. after this let it dry completely then apply paste in ICs and rehot to 310 to 375c up to 12min with Hot air gun, make sure ic's and board's doesnt move on the place during process.3. after this leave board to 15 min for come to normal temperature.4. then try to charge and use to check if solved (90% of cases it solved) other 10% possibility of camera flat cable damaged cause the same problem. so Best Of Luck.
