SOURCE: my hayward pool pump started making a humming
check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
SOURCE: I have a proline pool
C. MOTOR HUMS, BUT DOES NOT START—
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
http://www.haywardnet.com/products/Manuals/pdfs/manual113.pdf
SOURCE: When the motor/pump is powered
Your motor is covered under a 1 year manufacturers warranty. The issue you describe can be one of a couple problems all of which will lead to permanent motor failure if not corrected. I'd suggest you go back to the place of purchase or contact AOSmith for a warranty center near you.
You can find the warranty center online at:
http://www.aosmithmotors.com/AOSECatalog/ServiceshopLocator/ServiceShopLocator.aspx
John
