Those are POST code, error codes, you need to watch time and count them. report them.
leave the battery main out.
does it run ok now? yes/no.? main battery out?.
even new cheap batteries fail easy and hard and short out.
test it with no main battery. it can run on AC power for ever.
are you going to run the COIN cell RTC battery for 10 more years.
it wont make it..
this PC is 10 years old today (can be) so is RTC battery end of life. most fail in 5 to 7 years, says the pink bunny. (and is correct)
the manual shows how to replace it at the real HP Site,
fixya is not hp, not at all.
page 63 shows the way to the RTC
http://h10032.www1.hp.com/ctg/Manual/c01918142
if you power on the PC, and hammer the f10 key]
BIOS runs, its menus;
check the time and date here, if wrong the RTC battery is dead.
read page 3 how.
http://h10032.www1.hp.com/ctg/Manual/c01662442
HP caps lock POST blink code page is a horror of horrors
no 2008 listing, to name one flaw (2011 and newer sadly)
https://support.hp.com/us-en/product/hp-pavilion-dv7-1100-entertainment-notebook-pc-series/3756677/model/3807256/document/c01732674
here is a old post at HP, one guy 3 year ago said
LEDs blink 1 time
CPU
CPU not functional
LEDs blink 2 times
BIOS
BIOS corruption failure (RTC coin cell dead)
LEDs blink 3 times
Memory
Module error not functional
LEDs blink 4 times
Graphics
Graphics controller not functional
LEDs blink 5 times (or RTC dead)
System board
General system board failure
LEDs blink 6 times (or RTC battery dead)
BIOS
BIOS authentication failure
SOURCE: My laptop does no more boot up. As soon as i start
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue.
LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
Blink: 3 - Caps Lock/Num Lock
Memory
Blink: 4 - Caps Lock/Num Lock
Graphics
Blink: 5 - Caps Lock/Num Lock
System board
Blink: 6 - Caps Lock/Num Lock
BIOS
SOURCE: have a hp dv7-1240us laptop. the screen will not
this sounds like the inverter in the screen. I would start by subbing the lcd screen. Then try and external monitor. video problems are difficult. don't get frustrated
SOURCE: I have an HP Pavilion dv7-1130 Entertainment
This can be one of those tricky ones, especially if the issue is intermittent. The issue is usually either the ram or the motherboard (main board which everything plugs into). With the model of your unit I personally would suspect MoBo but it is worth checking.
This model should have a built in diagnostic. When you can get the unit to boot, you will need to pay attention to the options at the bottom of the screen when it is first powered on. As this model came with 2 different bios setups, we will have to cover both.
The easier, will have an option to press F9 for a startup options menu. On this menu an option for diagnostics will be listed. You are looking to do either a memory diagnostic or a full system diag.
The other possibility is that you will have the option to press F2 or F10 to enter the bios. Within the mess of menus, there will be an option to perform diagnostics.
If the ram passes the diagnostic, the you will be looking at a motherboard issue, which can become very costly to have repaired unless the unit is under Warranty,
Any further questions please respond.
Best of luck,
-halfs
SOURCE: My HP Pavilion dv5 1125nr
I would start with checking for a power problem. Is the battery dead? Is it plugged into the wall and the computer securely? have you checked the connection to the brick in the middle of the power chord? If any of these are loose, make sure and secure them, if this still doesn't work. unplug it, disconnect the battery, wait a minute and reconnect the battery, then plug everything in again and see if that solves it.
SOURCE: I have a HP Pavilion dv7-1232nr Laptop. As soon as
bad hard drive or memory card is loose more likely bad hard drive...have it tested...
