SOURCE: Maytag dishwasher MDB9100A---tub refills after cycle completed
Problem is actually a water valve that is near the water inlet. Cost is about 35 bucks to fix unless you listen to the guy on here and pay for parts that you don't need and pay them 20bucks for bad advice. Our total cost to fix this $35 dollar problem was an entire wasted Sat, 2 trips to the appliance repair parts place, $130 for the electrical control board that the "wiz" here said I needed--electronic parts and non returnable so we now have a new one that we didn't need.
SOURCE: maytag mdb8600awq dishwasher drains good 20 seconds and stops
Dont know if you still have this problem, what I did was this - press the start button and keep going until you reach the number '2'. Leave it at '2' and in a couple of seconds it will start draining the rest of the water. Worked for me.
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
SOURCE: Maytag dishwasher not draining completely
You have to remove the bottom kickplate to gain access to the drain pump and drain hose. You can remove the drain hose and blow through to see if the obstruction is in the hose. Take a look at the check valve for blockage. If a garbage disposal was just installed, make sure the knockout plug was removed.
SOURCE: Our dishwasher does not drain all the way. What could be the problem?
water pump is defective replace the pump about $40.00 and is not to hard to do. Take a picture of the washer underneath and send me a pick and I will give you the exact details of how to remove and replace it.
Hi
This issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Dishwasher not draining issue usually occurs due
Daniel
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
