There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
There are several possible causes for "memory card locked", "memory card error", formatting problems, or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed in this linked article.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
format the sdhc chip on the cam first before u do anything else. don't put it in the pc nor laptop. and don't try to take pics with the new card.....FORMAT THE SDHC CHIP WITH IT IN THE CAM FIRST, TRUST ME I HAD THE SAME PROBLEM AND NOW IM GOOD.
