SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
SOURCE: my jacuzzi toilet doesnt fill with enought water
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
SOURCE: When I flush the toilet,
Attached to the Flushvalve is a rubber stopper commonly called a flapper. If the flapper is worn this would cause the problem. Also sometimes the chain that attaches the flapper to the handle gets caught and the flapper sdoes not seat right. Check this, if it is clear and not obstructed try repalcing the flapper.
SOURCE: jacuzzi toilets installed one year
sounds like you may have debris in your lines. I was not aware of this until recently but, you should drain your water heater once a year to get rid of sediments that linger and travel through your lines causing possible blockage problems. Try turning your water valve off. Flush toilet so there is no water in the toilet or tank. Unscrew your line to shut off valve to make sure there's no debris. Good Luck!
keep going...i mean disconnect the supply line from the fill valve, hold the line into a bowl/bucket and slowly turn the water on. is there pressure? sorry for delayed response if you text me back i will try to answer expeditiously:)
