I need to know what error code 6 means, how i can fix it and also how i can check the receiver for my remote so that i can use auto start and power locks because my remote currently doesnt work
Hi there:
From Hyundai Owners Manual: Er6 - DISC ERROR - CHECK IF THE DISC IS INSERTED CORRECTLY IN THE CD PLAYER.
MAKE SURE THE DISC IS NOT SCRATCHED OR DAMAGED.
Error 6 means your laser isn't reading disc... needs replaced pick up
laser. I would try first to insert a clean up CD and test your CD
Player with an
original CD, if the problem persist,
you have to go to fix it to a specialist.
Hope this helps; also keep in mind that your feedback is important
and I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Testimonial: "Thank you ill try that! is there anything i can do about my remote not working? is there a way for me to reprogram it? or is it a problem with my receiver for the remote?"
SOURCE: 2001 accent code P1703
P1709 referrs to KICK DOWN SERVO SWITCH >- Open, short circuit DESCRIPTION • Detects the point of time when K/D band starts operation to control fluid pressure when K/D band operates. Detection condition • 1st or 3rd gear signal is present for more than 5 sec. • Transfer shaft speed is greater than 900 rpm • Fluid temperature is above 60°C • PCM receives an "OFF" signal from K/D servo s/w Check item • • • • • Harness & connnector • K/D servo s/w • K/D servo assembly
SOURCE: P0441 EVAP Emission Control System Purge Flow Fault 2001 Accent
It is always best to start simple on a lot of these things. This code indicates that somewhere in the evaporative system you have a leak that has set off the code. The gas cap is the most common culprit and that is where I would start. Buy a new gas cap and put it on. It may and should solve your problem. A lot of gas caps have rubber seals that do wear out over time. If this does not solve your problem simply use a search engine and type in p0441 a wealth of information will pop up. There are other possible causes and solutions but that's where I would start (with the gas cap)
SOURCE: Hyundai Accent (97, auto) wont shift out of Park,
ur solenoid is bad u can replace it which is kinda expensive or u can take ur center consil out and remove the peg that unlocks ur shifter the only thing ur lock override does is manually pulls it out. i just jammed a golf tee in it to keep it open and it seemed to work just fine
SOURCE: my check engine light on my 2001 hyundai accent gl
Most of the time they mean:
p0441 = Evaporative Emission System Incorrect Purge Flow
p0422 = Evaporative Emission Control System Leak Detected
(small leak)
MOre info at http://www.obd-codes.com/p0442
SOURCE: error code p1403
p1403 is a problem with the DTML sensor ... thats associated with the charcoal canister ... that is often caused by putting too much gas in the tank (overfilling) ... gas gets into the charcoal canister and contaminates it .. you could also have a bad sensor .. there are two .. one on the throttle body the other on the engine .. sometimes the wiring going to these sensors gets corroded or damaged .. contamination in the canister may clear itself in time if you avoid overfilling ..
