Computers & Internet Logo
Posted on Jun 29, 2012
I have lose the Volume Icon of a lop top windows 2006, it was my fault .
I was trying to close the Icon and it was gone.
1 Related Answer
Anonymous
  • 6771 Answers
  • Posted on Jun 29, 2012
SOURCE: I have lose volume icon of the screen my computer is a lop top Sony 2005
Go start menu, control panel, select sound and audio devices, make sure check mark is on place volume in the taskbar to the left, if not check it and click apply.
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Sound is on mute before entering ops. how to unmute
A) The hotkey is not Fn. That is the Function key. Press Fn and F8 hotkey at same time to decrease volume. Press Fn and F7 at same time to Mute volume.
B) Is 'ops' your system tray volume, or Device Manager? I suspect Device Manager.
C) Don't count on Windblows to upgrade your driver; or roll over driver; or play dead. (!O_O!)
DO count on Windoze to lose the address to the driver, though.
Suggest going to Asus Support, and download the Audio driver.
In the small window that comes up on the right, (Opening Audio_XP_xxxxxx), make sure there is a Green dot, in the small circle to the left of Save File.
If there isn't; left-click in the small circle to the left of Save File.
Then when fully downloaded in the small download window to the left; DOUBLE-click right on the file name.
In the next small window go to the far left, and click on
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
Restart your computer if not asked to do so.
(Close all windows, go back to your desktop screen. Start > Turn Off Computer > Restart)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sound not comeing at the takbar speak not show
Show the volume icon in the taskbarIf you end up finding to impractical notification area to have the speaker icon displayed inside the taskbar, you can tell Windows 7 to resume showing the volume, same steps as before:
  • Click on the start menu, and type "volume"
  • Select the Volume's dropdown menu, and change its value from "Off" back to "On"
  • Click OK to confirm and close the Control Panel
Windows 7 has now resumed displaying the volume icon in the taskbar!
Else IF windows XP
goto control panel click sound and audio device then check Place volume icon in the taskbar.
Hi I am using my LG 42LH3000 LCD TV as a monitor for my Dell M65 Precision Laptop, which works fine but only as long as i have the lop top open, as soon as i close the lid of the lap top the TV goes blank....
Make sure you set the right action for the laptop closing. Right click on the battery or plug icon on far right of the windows bar the go to power option.
Then make sure that for any power mode the computer won't enter the sleep state when closing the lid.
If this doesn't work, you might have a dell specific software the takes care of the power setting and override the windows default one, try to find it and alter the settings as mentionned above.
good luck
Theres no sound coming out from my lop top i think i deleted yesterday my sound and audio device and i cant see my installer any more...thanks
Firstly check the volume is not low or muted on both windows and the speakers. In windows click the speaker icon in the bottom right of your screen, check the volume is turned up. Then click mixer or advanced and check that all volumes are turned up.
If using a laptop, check that the hotkey control for volume is on. You will see an audio icon on one of your ‘F’ keys, hold the Fn button located near the ctrl and press the volume function key.
Next open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.
If you are still having issues the sound card may be faulty, this is usually integrated into the motherboard. In a desktop PC you could buy a new PCI soundcard if you have a spare PCI slot in your machine.
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
1helpful
Vista wont let my adjust my Volume
try restarting the computer, then go back to the Notification Area for your Taskbar, then verify if the volume icon is active for you to select.
otherwise, check this site
http://helpdeskgeek.com/windows-xp-tips/sound-or-volume-tray-icon-missing-in-windows-vista/
I heard some grounded sound in my speaker when im using it especialy when my volume is low.my lop top is hp 530 is it compatible to my lop top im using altec vs2421.
are you referring to low frequency hum? that's a ground issue..check all your power cables, and eliminate the two prong approach..and plug your speakers into the wall directly to get the ground action
No sound for windows xp.
Go back into your device manager. Rught click on your sound card or sound device and say uninstall. After it is uninstalled, don't close device manager. Go to very top to your your computer's name or my computer if you didn't name it. Right click and click on scan for hardware changes. Windows will find your device and reinstall in a second. This will give you cack your volume control and sound.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
