Another potential issue that I have found is that you may have very strong water pressure coming into the fridge, which might make the water jump and splash out of the tray. Perhaps turning down the water pressure somehow might be an easy (and cheap) solution?
Had similar prob. the ice cube tray is allowing the ice not to fully release.the tray must be replaced.
SOURCE: Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
The icemaker was operating correctly; however, water overflows the ice tray and runs down the left side of the freezer and freez. Ice cubes are generated, but over a day or two ice builds up whereas I need the remove it. Again, there is no leakage in the back near the value . . . how can I correct this problem?
where on the ice-maker can I adjust the water flow that comes into the ice tray?
