Jet tech model 747, will not reach operating temps or run a cycle
Check the inlet screen to the water circulating pump and the water heater element for lime buildup. I've seen a heater element that had a 1/4" thick layer of lime encasing it. The inlet also had some lime and other debris clogging the screen. After carefully chipping away as much as was practical and running lime remover (such as CLR) through the machine, it heated the water much more quickly and had an effective spray.
To prevent a recurrence of this problem, make sure you have a functional water softener ahead of the water heater feeding the machine.
