I purchased a Kogi L9CH monitor recently, when I received it and set it up, I noticed that the screen was overly bright and green, I went into the settings and lowered the green to zero and lowered the brightness a bit and that helped some, but just to see if I could do better I played with about all the features. when I hit the auto tune feature however, I made a no-no. the screen display shifted far right and down, when I went back into vertical and horizontal position settings I could not get my display back into normal range even with max left and upward settings, redoing auto tune and restore factory settings options did not fix this, resetting the eprom did not help either, any suggestions on how to get my screen back into the frame?
you can go to any monitor repair shop & get it.
just tell model no. or take the sample which is defective.
good luck.
Same problem: after auto tune, the image slid far right and down, and I can't get it to go back into a normal range.
How do I set all setting
back to factory setting?
Unplug your vga cable power off the unit hold the up arrow down
at the same time power the unit back on you will see a message “RESET
EPROM” power off the unit plug back your vga cable and power
back up.
This wills also most of the problem on our LCD monitors
Thank you Kirk! That worked. Anything that was supposed to be blue was green. Great tip. Thanks again!
Thanks Kirk! Thought I needed to buy a new monitor. The reset fixed all the color problems Ive been having. Thanks again,,, Rob
