He is asking for a security code and i have tried all the numbers that i know please help
SOURCE: I dont know the security code to my Nokia 6085
call your service company (i.e. sprint tmobile, altell.) they can provide you with a code or they might be able to get you a whole new phone... tmobile has done both for me….
Please rate my solution I need feedback J thanks
SOURCE: how to unlock security keyguard on nokia 5310 ???
I work for Nokia and i can help you this will only work for Nokia 5310 what you do is the following
Step 1 : Type in : 11111
Step 2: Type in: 22222
Step 3: Type in: 33333
Step 4: Type in 44444
Step 5: Type in: 55555
Step 6: Type in: 66666
Step 7: Type in: 77777
Step 8: Type in: 88888
Step 9: Type in: 99999
Step 10: Type in: 00000
Step 11: Take battery out wait a good 10 minutes as this resets the code
turn your phone on and repeat the same process above in the same order and wait 10 more minutes and the turn it on it will ask for your security code as you have followed the steps the code will now be to the default of: 12345 then enter your new code and the verify it by entering the new code you just entered and away you go thanks.
Daniel Carter
Nokia Support
SOURCE: security code for restore factory settings
12345 s the default security code for nokia....if u forget the code then do one thing..better re install the firmware....all ur settings ll come to the factory setting position...but make sure u have all the contacts as it ll get erased during the process.......
