My phone will not ring when someone calls my phone line. The line indicates that someone is calling, but I hear no ring. I cannot find how to turn the ring back on.
Same issue; I changed the volume and ring type several times but the phoen continues not to ring. Please advise.Same issue; I changed the volume and ring type several times but the phoen continues not to ring. Please advise.
You can't post conmments that contain an email address.
Hard to answer because your problem description does not match the part. Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
You will need to go into programming and set all the phones to ring.
Log in: Feature **266344, 266344
Scroll to Configuration > Line Access > Enter set number > Scroll to Ringing> Then go to each line and set it to ring.
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
