I know that's not all that helpful at the moment but I know that the no video out (to run a 2nd tv) that's there way of getting you to have a 2nd sky box I hope that is not the case with audio but it is a possibility ..try using phono plugs
audio out (RED WHITE omd audio in on your amp I have a look about and repost
SOURCE: dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
SOURCE: Wharfedale DVD recorder, no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
