Power light blinks for several minutes then goes solid but still no pic. cannot power box off with remote or power button on tv
1) you must open the remote code, and resolder all points colder points solder.
2) clean any keypads contacts, with special spray contact cleaner removing oxide, dust, etc.
3) Test the connection from power box, otherwise the button from power box is defective or clean with special spray contacta. unplugged the power box. and try.
4) if the problem persist you must go to the repair shop TV for fix it.
God bless you
SOURCE: RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
SOURCE: Hughes box wont power on.
Sorry it took so long to reply to your request for help.This Direct TV box has had a component failure. You will need to call Direct TV and have them replace the box. You can call Direct TV Customer Support at this telephone number 1-888-667-7463. Tell them that you are having a problem with Direct TV box and need a replacement. I hope this information help you solve your problem with the Direct TV box failure. Thank you for using FixYa and have a nice day!
SOURCE: NEED MY RCA CONVERTER REMOTE TO CONTROL A MAGNAVOX DVD COMBO TV
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
SOURCE: emerson jumbo remote
http://www.oldephartz.com/cterrian/manuals/JumboRemote.pdf THIS IS THE MANUAL FOR EMERSON JUMBO UNIVERSAL REMOTE WITH ALL THE CODES FOR ALL TVS VCR ETC...AND THEY REALLY WORK, I HAVE ONE AS WELL.
