I have a 11 year old Fisher Paykel DD603 dishwasher and the cycle is stuck on "normal". I can't change it to any other cycle. I've tried turning off the power button as well as throwing the circuit breaker in an attempt to reset it- a lll to no avail. Is there a quick fix for this problem?
SOURCE: Fisher paykel DD603 top drawer starts cycle then
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
THIS IS SIMALAR TO THE BOSCH UNIT, IF THERE IS NO BOTTOM COVER TO REMOVE YOU NEED TO TAKE THE SCREWS OUT OR THE TOP INSIDE THAT HOLD IT TO THE COUNTER TOP, PULL THE UNIT OUT SLOWLY, TURN OFF THE WATER SUPPLY SHOULD COME OFF THE HOT SIDE OF YOUR FEED LINE TO THE FAUCET UNDER THE KIT SINK, THE WATER SUPPLY IS ON THE LEFT LOOKING AT IT AND THE ELECTRIC IS ON THE RIGHT IF YOU CAN PULL IT OUT ABOUT 8 INCHES YOU CAN GET TO BOTH CONNECTIONS TO BE ABLE TO DISCONNET PULL OUT ALL THE WAY GET BEHIND IT AND CHANGE WHAT EVER YOU NEED TO
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
I have contacted the company and they say to get a device person out.Nothing else I can do?
