I need tv codes for my tv codes for xkd sl 083 remote control watch mainly for sanyo n element
Try these 001,014,018,022,029,032,034,038,052,055,089,118,138,151,191,224,233,234,407,412,430 ive got the same thing one of these codes are it
I need help i cannot turn my hittachi tv on and off
Http://imageshack.us/g/528/20120701150749.jpg/
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
SOURCE: sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
you have any for the element tv?
