It's that flapper that releses the ice. There is one screw on the upper right side. Do I remove that and the light bulb to remove that section to remove and clean? Model SS2 MaytagIt's that flapper that releses the ice. There is one screw on the upper right side. Do I remove that and the light bulb to remove that section to remove and clean? Model SS2 Maytag
You can't post conmments that contain an email address.
This is usually not hard to fix. Either the tab that hold the dispenser actuator is broken or the ice guide may have come loose. Repairclinic.com has a nice video on how to fix this.
Check to see if the actuator is lifting up. sometimes these freeze and won't lift the arm that releases that grinding blades. It is in the back panel behind the ice bucket. Remove the bucket and hit the light switch. Then hit the ice actuator flap on the door and see if the little "stirrup" looking thing jumps up. There is usually a clicking sound when it lifts. it could be frozen or just bad.
You need to thaw out the ice machine and see if it works after you thaw it out if that does not fix the problem then the control arm for the ice dispenser is bent.
Either pass side actuator was not plugged in(rear most unit on heater of the 2 actuators for dual zone),(front unit which is an exact opposite is on the opposite side of the heater on the front side) or flap is jammed inside heater assembly. Open the glove compartment and unscrew the door to remove. Look to the left......remove the actuator and move the flap....if it moves and the unit was plugged in replace the actuator for the pass side.
There is a vacuum operated actuator that is in the venting system When you switch your control knob, a vaccum pressure is applied to this actuator. Then the actuator moves a flap that controls the warm air/cold air flow. The flap can get stuck, or the actuator can become leaky or weak
Push back release rod - 9 - by operating remote control unlock and remove bolt - 2 -.
Remove rubber part - 8 - from tank filler flange and swivel out tank flap unit - 1 - from side panel - 7 -.Assembly piece - 4 - and actuator - 6 - is installed.
Install tank flap unit - 1 - (rubber part rolled up) with hinge side first.
Bolt tank flap unit - 1 - and assembly piece - 4 - with bolt - 2 -.
Tightening torques: Bolts - 2 - 1.5 Nm
Remove side luggage compartment trim.
Disconnect harness connector at actuator - 6 -.
Remove actuator - 6 - using special tool Socket wrench T 10010 from angled mounting bracket.
Remove actuator - 6 - together with release rod - 9 - from seal - 5 - and assembly piece - 4 -.
Installing Installation is reverse of removal. Tightening torques: Bolts for actuator - 6 - 1.5 Nm .
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
