My RS2578BB was doing the same thing. Freezer Temp. flashing at 8 degrees but the freezer was obviously not that cool. Ice had built up at the bottom drain and collected on the coils causing the thermostat to be inaccurate.
Solution: Unplug refrigerator. Remove shelves and drawers, remove cover plate and check for ice build up at bottom drain. Use a hair dryer for a quick defrost, remove ice build up, plug refrigerator back in, reset temperature, turn on power freeze. My temp went from 80 to 36 in less than 2 hours.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
