I have a Maytag portable dishwasher that is almost 2 years old (MDC4650AWW). My problem is that is doesn't drain completely. (It is level) When it tries to drain, it trickles out of the hose. In fact, most times I run it, there is about 1-2 inches of water on the bottom of the dishwasher left over so i don't feel the dishes are actually being rinsed clean. When I pull the hose in and out while it's draining, it tends to come out better. It's as if something is stuck in the hose. has anyone else had this problem and fixed it?
I have had the same problem and shaking the hose was a
temporary fix. I decided to take apart the dishwasher to see if there was some
kind of a clog. What I found, after taking off the top and back is that the
drain hose gets kinked by the fill hose. They both run up the side of the
machine and back down and are held in place by a cable tie. Over time the drain
hose must have gotten soft and with the fill hose on top of it, it kinks over
the cable tie. Therefore I cut the cable tie, put the drain hose on top of the
fill hose and put on a new cable tie and this seems to have solved the problem
because the water now drains as fast as did when new.
Try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
I have the same problem as beldo02's maytag portable dishwasher not draining but mine also makes a terrible noise during the wash cycle. My dishwasher is 2 years old....is this a common problem with this model?
