Exercise & Fitness Logo
A
Anonymous Posted on Jun 26, 2012
Ptfitness 2 in 1 pedometer - need to change from metric to imperial
Have read the manual - says you can do it but the instructions are not clear. Up arrow/down arrow does not change metric/imperial mode it simply changes what you are programming (ie. weight, age etc.)
5 Related Answers
Anonymous
  • 1734 Answers
  • Posted on Jul 23, 2009
SOURCE: reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Anonymous
  • Posted on Jan 03, 2010
SOURCE: voicezone talking pedometer instructions, turn off alarm
Push both the up and down buttons at the same time. You might have to repeat this two or three times. It will tell you when the alarm is off.
Boneebone
  • 973 Answers
  • Posted on May 25, 2010
SOURCE: lost my manual and need to program my "New Balance...
Contact New Balance Customer Service: (800) 253-7463
Monday – Friday
8:30AM to 8:00PM ET
Search our FAQs
CarlGlas
Carl Glas
  • 283 Answers
  • Posted on Jul 07, 2010
SOURCE: need instructions on how to use my 340 sportline
http://www.sportline.com/manuals/340.pdf
Anonymous
  • 66 Answers
  • Posted on Aug 03, 2010
SOURCE: Changing metric to Imperial on Suunto Vector
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
It's in the manual. I did it on mine.
2answers
Have 2011 cadillac dst, the speedometer changed from english to metrics, checked manual, says english, but still reads metrics
Hi. You would select Language for English. You need to scroll and select UNITS. From there you can choose between US, Metric and Imperial.
My dodge journey 2015 change to miles from km I would like to change it back
Hey, all you need to do is change your settings from imperial to metric or metric to imperial.
Your owners manual will have the exact steps on how to perform that, be sure to give that a good read if you haven't yet about 15 minutes and you'll learn a whole lot of cool features you might not have known about your car yet.
1helpful
2answers
Changing from metric to us
THe info you need will be in the manual. If you go to the manufacturers website, it should be downloadable..
Without the specific make and model we can';t be of more help.
1helpful
Can this model be changed fom Metric to Imperial? Thanks Model pedometer HJ-112 by Omron
Why do you want to change it from Metric to Imperial? Omron Pedometer works really fine and I don't think there's any need to change it.
2helpful
I have lost the instruction manual how do i change the setting from miles to kilometers
If you have the model, Ped Alarm - PE319, it doesn't have metric units. Correctly, Brunton sells one model programmed for metric and one with Imperial units. The units are fixed, and no conversion information is programmed into the units. The product web site doesn't come up correctly on my browsers: http://www.brunton.com/product.php?id=45. However a FAQ is available at http://www.brunton.com/faq.php . The manuals are also available here, for the Ped Alarm, click on Instruments and look in the list for that model (followed by .PDF).
I wish I could be of more help.
2helpful
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    1helpful
    3answers
    New Aqualand promaster dive watch JP1010-01L. Temperature currently displayed in C. How do I change display to F.
    Called Citizen Customer Service and was told that there is no way to change it. These watches come set with metric or imperial scales from the factory and cannot be changed.
    IT SUCKS !!!!!
    Top Life Fitness Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
