Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Whirlpool Gold Quiet Partner IV issue with soap dispenser
It seems my dishwasher soap dispenser is not releasing the dishwasher soap at the appropriate time. When I run the dishwasher and go to unload, there is soap oozing out of the open dispenser. It seems as if it is releasing the soap too late into the cycle? My dishes are spotty and white residue all over them. I have tried both solid powder soap and liquid soap, as well as the little solid soap cubes with Jet Dry. HELP!!!
  • mondayfam Feb 25, 2009
    Seems that the soap is not getting dispensed properly.  Every time I run a cycle and it finishes, I open the door and half of the (powder) soap is stll caked in the dispenser. Bottom dishes seem to get clean enough, but top rach is always still dirty.
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Posted on Mar 14, 2009
  • 126 Answers
I'd check the spray arms it may be there is not enough water or the wataer is not getting where it needs to be to disperse the soap. that is where I'd start.
Posted on Jan 16, 2009
SOURCE:
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
Wet dishes
Hello
The heat dry button must be lit up or you are using air dry instead!
ican
Please leave a rating before you leave
Dec 10, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap holder still has dry soap after wash cycle
you will have to check the wax motor that opens the door on the dispenser it is on the inside door panel it is most likely bad
Aug 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
911 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
