Tried taking off the metal piece on top of the pink roller, but it's wedged in there. Cannot get out the laminate and paper that's melted/jammed inside.
You need to loose the vertical plastic wall on the left side, and pull
it up and to the left, only then you would be able to take pink rollers
and metal piece away. Step by step do this (BTW, make pictures of each
step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench.
Then both parts (14) from both sides [4 in total]. Then both parts (2).
Then take out screws that are holding this vertical plastic wall place.
There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical
plastic wall on the left side of laminator. If not, try loosing some
screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Testimonial: "Thanks! It's all fixed now and put back together!"
Could you please send a diagram of how to put the laminator back together after the severe jam with the H425 Heat seal laminator? Thank you,
[email protected]
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Thanks!
the lamination paper fed into the laminator but did not come out the other side. it is jammed inside the laminator how do i get it out?
How do you open the lid to remove a jammed and melted page from the laminator
Paper jammed in the GBC Combbind C800Pro and unable to loosen it. What do I do?
