I changed the batteries and now I have no display or function at all. Everything worked fine before changing batteries, and I have done this before with no problems. Any ideas???
I own a 2009 Road Glide, I was having problems with the display fading and some of the functions not working. I took out the stereo and used my compressor to blow out the dust, use low air pressure as you don't want to damage anything. Now so far everything is back to normal. Good Luck.
The radio on most american vehicles has two fuses powering its functions. Ie--CD player runes but is not amplified. Clock works but not radio. Check all the fuse headings again...ALL FUSE PANELS, there are usually more than one. sometimes 2 panels Inside and under the hood as well
its the norm for fossils to have 2 batterys one for the hand function and one for the back display. it depends on year or what movement is fitted.you will have a 3v battery for back display and under it there maybe a smaller cell 1.5 .it could be a 2016 or even2025 3voltand a 364 or 377 small cell but you wont know untill the backs off the watch and remember you need it resealing to make sure its water resistant after its been repaired this needs to be done by fossil or a good watch repair service like Intime watch services uk..you have to AC the movement as well to make sure all functions work it needs to be done by a trained tech..
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Check power settings as it may be in battery saving mode, for games it should be set to maximum performance. There will be settings for brightness and contrast possibly using the function key and cursor arrows. It may help to change the screen, which is moderately difficult if you have a disassembly diagram, but it is worth trying to change the inverter first.
First try
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it.
This should connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the button on
the mouse. This should be done whenever you change batteries or
glitch.
Then if that doesn't work try
Normal
0
glitch.
Hope this helps you. Bud
