Hello, I have just recently renamed some folders on my Sony Walkman music folder, but after I disconnect it from the PC and try to access them on the Walkman device, the folders don't show up at all. Though I can see the songs inside are stored on the device.
How do I make them (re)appear?
And jesus, why require from the topic author to type the product model, when the product is not listed at all? I had to choose a wrong product in "What product is it about?" because it didn't consider the real one valid. The product I'm using is Sony NWZ-A826.
SOURCE: pc does not open folders in w200i when connected through usb
first you go to your mobile menu and select your memmort card and select any (picturs,sounds etc.......) then click option select format memmory stick please enter your security no: then Ok
switch off your mobile phone and on Then connect your mobile phone your pc And find our your any folder Nd enjooooooooooooyyyyyyyyyyyyyyyy...............,,,,,,,,,,
Contact Any problem :- [email protected]
SOURCE: downloading music from pc to phone
Have you installed and tested the drivers? Are you able to copy pictures across? If you're using the bundled software to copy files across, try opening the phone's folder using Windows Explorer and copying them straight over. This uses the obex drivers - USB mass storage and file transfer.
Otherwise, there may be a problem with the file you downloaded. Check it's size - if it's of an unusually small size (under 300 KB, unless it's a REALLY short song!) it may be corrupt. Try ripping a song from a CD with Windows Media Player, then copying that across. Be sure to change the rip settings to MP3.
Hope this is of some help...
SOURCE: sony ericsson W580i ringtone issues
look into you file folder for the ringtone it will be in there
SOURCE: Sony W580i - Cannot play MP3s On "Walkman" Setting
TRY A MASTER RESET OF THE PHOE IF THAT DOES NOT WORK THEN YOU MAY HAVE TO GET THE PHONE FLASH TRY ONLINE AT TOPSONY.COM OR TAKE THE PHONE TO A MOBILE SERVICE CENTER
I found out! The device could not find the folders because I have decapitalized the letters in the root music folder (MUSIC > Music). I didn't thought it would have trouble doing so, but it works now.
