Technics SL-DZ1200 Turntable Logo
Anonymous Posted on Dec 02, 2017
Technics SL-DZ1200 no sound on turntable mode
Hello!! I would like to ask you about my Technics SL-DZ1200 . i have a strange problem.When i load a cd in turntable mode,my player cant play it more than a few seconds.then it stops.the "vinyl" is working(turning arround) but no sound at all... please help me,what can i do for it??any other with same problem??
Level 3:
  • Technics Master 19,187 Answers
  • Posted on Dec 02, 2017
Technics Master
Level 3:
Answers
19187
Questions
0
Helped
4343748
Points
82261
5 Related Answers
Anonymous
  • Posted on Feb 13, 2008
SOURCE: technics sl-dz1200 parts
THEY HAVE THE PARTS AT PANASONIC.COM. THEY SHIP ANY WHERE....JUST TYPE IN MODEL#...
Anonymous
  • 33 Answers
  • Posted on Feb 17, 2008
SOURCE: all my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
A
Anonymous
  • Posted on Feb 24, 2008
SOURCE: Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Anonymous
  • 515 Answers
SOURCE: Technics sl-dz1200
Here is the direct link to the manual - FREE!
You'll need Adobe Acrobat to view it.
Enjoy!
- DJPROLAB
Anonymous
  • 10 Answers
  • Posted on Jul 11, 2009
SOURCE: Technics SL-DZ 1200
Upgrade the firmware. you need a small SD card.
I forget what keys to hold down at power up.. or where to download the update
BUT.. it may work.. I am sure you can find it..
Or maybe you have gunk on the tracking servo's gears "linear' a grain of grit.
working on the DZ is easy if you have any electronics background.
2answers
My player drags in turntable mode
It must be reseted. Try unplug power for ten minutes and replug. If no result check if you can remove its internal small battery and refit.
My technicssl-dz1200 sd card keeps telling me no sd audio track.
try loading the audio again on your computer. maybe it didn't load properly. also try switching the technics deck off and back on. maybe it is having a bad day and needs to restart.
1helpful
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
Hi, i lookink for slip surface for technics sl-dz 1200 thanks for help
try these sites :
http://www.studiospares.com/bin/venda?ex=co_wizr-locayta&template=wz_locayta&pageno=1&perpage=10&collate=pdxtleadtype%3Apdxtplug1%3Apdxtplug2%3Apdxtlength%3Apdxtcolour%3Aivtype%3Aprice%3Acat%3Abrand%3Apdxtpowerrating%3Apdxtimpedance%3Apdxtbacktype%3Apdxtheight%3Apdxtinputs%3Apdxtoutputs%3Apdxtinternalmic%3Apdxtrecordingmedium%3Apdxtscardtype%3Apdxtscardmidiio%3Apdxtscardinputs%3Apdxtscardoutputs&refine_sort_alph=&fieldrtype=type&termtextrtype=invt&typertype=exact&typekeywordsearch=keyword&termtextkeywordsearch=Technics+SL-DZ1200+
OR :
http://djbooth.pgpartner.com/search_getprod.php/masterid=8918418/search=Technics%20SL-DZ1200%20/st=query
Turntable mode does not work
CHECK SENSOR & SENSOR SHEET UNIT DISPLAY UNIT
MAKE SURE NO LIQUID WAS DROPPED INTO UNIT
How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Pitch
There might be something in the reader that needs to cleaned out. Or the cd reader itself might be damaged. In either case, you'll need professional help.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
