Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Logo
Posted on Jun 26, 2012
My whirlpool cabrio front loader dryer start button does not work it is a raised plastic button that went flat, can you help
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Mar 26, 2007
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Anonymous
  • Posted on Apr 21, 2009
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
John Morganti
  • 864 Answers
  • Posted on May 29, 2009
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Anonymous
  • 27 Answers
  • Posted on Jun 15, 2009
SOURCE: I have a cabrio dryer and it will not start. It
control panel is bad, use your warranty and get it fixed for free since it is only 2 weeks old
Anonymous
  • Posted on Oct 14, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
1helpful
2answers
Whirlpool cabrio dryer has power but won't start
I had the same problem. It's as simple as a piece of plastic that broke off from inside the user interface housing which is what depresses when you push the start button. Since it broke, clicking on the start button did nothing.
To fix it, I just superglued the piece back together and it works perfectly again.
I lost Power from a Thunder Storm and now my Whirlpool Cabrio top loader won't open
Thats sounds as if the lock asm is stuck. As soon as the power went off the lock would have de-energized and should have opened.
Too check the lacth for sticking open the top by placing a putty knife in the seam between the top/front cabinet panel at the corners and push in to release the clips that hold the top to cabinet then raise top and see if something appears to be stuck on latch asm.
Gene
2helpful
2answers
Our Whirlpool Cabrio Elecetric dryer will not start. Model is WED6200SW1. We had just finsihed drying a load and put a 2nd load in, but it won't start. All the light come on. Could it be a sensor...
it could be that or it could be the start button, you can check the button by adding a jumper in the wires that go to it,, this should be done as a check and not left that way,, for safety
Power is on but wont start on my Whirlpool Cabrio Dryer
The first place any tech is going start at is : Is the start switch working
I personaly have seen the plastic part that pushes the switch break and the control housing then needs replaced.
1helpful
2answers
HOW TO PUT DRYER RACK INTO WHIRLPOOL CABRIO #WGD6600VWO
If it is a dryer with the lint screen on top place the two ends of the metal loop into the two holes closest to the plastic clips on the bottom of the rack. The clip the metal bar down into the clips and the multi-bent part of the metal ring are now atteched to the bottom of the plastic rack. Turn it over and place the metal ring in to the back of the dryer and the front lip of th plastic rack then hangs loosly over the lip of the bottom of the opening of the dryer. It will all tighten up when you close the door. Hope this helps
3helpful
3answers
Whirlpool Duet Ghw9150pw1 would not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
