Sounds like a dry joint on the board to me
I've had this problem with other sound equipment. For me, it was a heat issue and there was an auto shut off feature to save the unit from over heating. I would especially think this is the case if it turns back on without problem after another 10 minutes of being off.
You could try turning off phantom power if it isn't needed to run your mics. Or making sure it is in a spot that allows maximum air flow through the head.
Hope this helps! Don't forget to rate!
