Hi have a repair shop, and you know it’s a very common problem on this model. 90% of the cases I found liquid damage in the phone damaging the Sim Ic, it’s a little square one near your sim reader, you can also clean around that with a soft tooth brush and mentholated sprits. Don’t fiddle with your sin contact/ reader if no damage visible to the eye.
Near d sim tray there ll b a sim ic
put some solution(ipa)and show in blower...
still it dosent work means replace d ic or try jumper there
Open your sim card..take a pin or something that u can pull up the sim card connector..there are six connector in that sim card slot.ok..but,be careful..the connector is very soft..so,pull up very carefully..ok..not too much..only a little..after that,try put your sim card,,if u have the same prob,try use another sim card..if another sin card ok,your sim card is prob..try to clean your sim card by using rubber paper...
tell me if anything.tq.
Look that the sim is placed right and lock the sim cover the stell one tightly unless it makes the sound and ur problem is solved else take it to a mecanic
you need to open your phone and check the connection of the sim card slot. look for loose soldered parts, or it need to be reformat/reprogram.
jumper contak servise nokia 2626
