Question about Sharp Refrigerators
Sharp Fridge is collecting water under veg compartment
Model SJ-PT690RS
  • Michel Qasir Jun 28, 2012
    My fridge model is sealed from the back completely and I could no find the drainage pipe from inside. Unfortunately also I could not manage to download a manual from internet to show me how to find the drainage system.
    The problem is still persisting and I have to collect water from the inside bottom of the fridge on daily basis.
    The only thing I am planning to do is to switch off the fridge for 24 hours the restart it hoping that if there is frozen water in the drain pipe will thaw.
    Please let me know if there is another way to sort this matter out.
    Thanks,
    Sergeant:
    Champion:
  • Sharp Expert
  • 279 Answers
Drain Try is full with water its fix on compresser. Empty Drain try and try.
Posted on Mar 03, 2015
SOURCE:
SOURCE: ice build up
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
Posted on Mar 23, 2009
  • 958 Answers
SOURCE: Candy frost free fridge freezer
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
peyton32034
  • 410 Answers
SOURCE: Model 78182891 Coldspot with excessive water Collecting in Refrig
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs so the answer is yes it may occur again in the future. But folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post back if you have any questions and I'll gladly help you out Thanks Peyton
Posted on Mar 17, 2009
lojacksdad
  • 121 Answers
SOURCE: Water collecting in bottom of fridge
you have a blocked drain there should be a small cup on the back wall top of the fridge that can be taken out and cleaned or the bottom of the freezer
Posted on Jul 06, 2009
woodchuck789
  • 4070 Answers
SOURCE: water gathering at bottom of fridge.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 25, 2009
Sharp SJ F60PC SL refrigerator-freezer is freezing the refrigerator compartment.
I would take a look to make sure your coils are not frozen or covered with ice on the inside of the fridge on the back wall and also double check the drain line on the back.
You could have a faulty switch that controls the thermostat as well.
Jan 17, 2018 | Sharp Refrigerators
Why is my Kelvinator 400 twin air no frost fridge leaking water under veg compartment
Good morning Barbara, from what you are describing it sounds like the evaporator drain is clogged. You need to empty the freezer and remove any access panels to get to the drain. Get a bowl of hot water and a turkey baster,then use the baster to force the water into the drain to clear the blockage. Not real familiar with that model,so check under the vegetable compartment to see if the drain is under it first. Hope that helps.
Jan 03, 2018 | Kelvinator Refrigerators
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Water under the veg. compartment in sharp SJ-T520R-SL refridgerater
Hi,at the back of the fridge there is useuly a drain hole if its blocked then instead of the water going out of the back of the fridge its staying in the fridge,if there is one just get a peice of wire and push down hole to remove any blockidge,also what can couse itis if your food in the fridge is tuching the back off the fridge wall then the water runs down the food inside the fridge instead off going down the drain hole.
hope this was some help,all the best.
Apr 18, 2015 | Sharp Refrigerators
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
A lot of water collects in the ridge under the veg-fruit crispers. I have to constantly sop it up with towels. This model does not have a drip tray under the storage area
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | GE GTH18EBT Top Freezer Refrigerator
54409 // water accumulates under veg and fruit drawers?
Look inside at the back to see if there is a collecting troff which collectes the water runing down the cool plate. In the middle of the troff is a run off hole which takes the water outside to the back to an evaporation tray. if this hole gets blocked it floods the fridge and you know the rest. Some fridges have a looped plug which you pull out of the troff hole to clear the blockage. I know this as my fridge does this too.
Jul 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Whirlpool refrigerator (Model ET21GKXHT01) has water on the shelves, in and under the crispers. I can't see where it's coming from. I don't see any plugged hoses. Help!
condensation with collect on any shinny surface,have you put uncovered food in the fridge or left the door open,refilled the fridge with food from the mall,especially veg,or is it very humid at this time.also check door seals for fit all round as an air leak will not help.
Jul 20, 2010 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
3,784 people viewed this question
Top Sharp Refrigerators Experts
geob91
Elie Balas
Vernon Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
