SOURCE: Mitsubishi VS- 50609
Hello videopro4uJC,
I gave this advice out before and it applies in this case so here goes:
What is happening is that your convergence amplifier modules are beginning to go bad. These amplifiers are what amplify the signals used for convergence (how the RGB lights line up on each other) when they go bad the RGB lights tend to bow towards the center of the TV and the colors begin to mis-align. There are many sites devoted to doing the changing of the amplifiers yourself,however although these sites are accurate and give the instructions on how to change the amplifiers they do very little for actual troubleshooting and finding the underlying cause of the problem. In most cases its just that the amp modules have gone bad, but sometimes there is an overheating problem that triggers the damage. I would suggest having a TV repair person come to your place to check the problem and to fix it. The repair should cost about $250.00
SOURCE: Mitsubishi vs-50609 wont stay powered on
Good day, carriegomez;
If still have problem try this or at least you will have an idea of what's wrong:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
I hope this was helpful, big IRISH.
SOURCE: Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
SOURCE: Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
