SOURCE: archos av700 charging problem
Hi
Buy an external charger as the charging circuit has blown.
You can get them from ebay.
Cheers Boyce - Boyski1960
SOURCE: Archos 605 Wifi . Can't Write To Drive
Make sure when you format archos its in file system fat32. I can only assume you need check folder permissions, which is why you cannot write to drive.
SOURCE: Archos 605 WiFi "Cannot play video! Please Check"...
Happens to me at least once a week! Use the reset button - works every time.
SOURCE: Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
