SOURCE: How to get factory settings for my Dell Inspiron 1505
hold ctrl down and tap f11 while booting...then restore menu will come...
SOURCE: dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
SOURCE: restore dell inspiron b130 to factory settings
restart the laptop... as soon as you see the big blue DELL screen hold ctrl and press F11.
if done right, this should bring up the dell restore utility, just follow the prompts. takes maybe 15 minutes.
SOURCE: how to restore dell inspiron 4150 to factory
frist u should down load driver of which is in you r computer 's function as modeam,sound vj...etc. you can serch in google it . u may serch in this way, xp or vista supported softwere for del inspiron 4150. To days we are getting many types lapto's driver on free in webside.
SOURCE: how do I restore factory settings on my dell
Turn
off and reboot your computer. When you see the Windows flash screen,
depress "CTRL" and "F11". Be sure to press them simultaneously and
release them simultaneously.
Select "Restore" in the "Dell PC to
restore by Symantec" window and press "Enter".
Highlight and
select "Confirm" when the message shows that you wiill lose all data if
you continue. This will begin the restore process. It usually takes
about 10 minutes or so. When it's done, you should receive a message
that states the system recovery process was successful.
Select
"Finish" to complete the process and restart your system.
Shutdown
and restart your computer. Keep pressing "F8" until you see the
"Advanced Boot Options" menu. You must depress the keys before the
Windows Logo screen appears. If you wait until after the screen appears
and then press "F8", it's too late and you'll have to reboot the system
and try again.
Navigate to the "Repair your computer" option
Select
the appropriate language and click "Next".
Sign onto the system
as an administrator. Without administrative privileges, you will be
unable to perform the system restore.
Select "Dell Factory Image
Restore" and click "Next".
Place a check in the check box next to
the text that says "Yes, reformat hard drive and restore System
Software to factory condition" and click "Next".
Click "Finish"
to complete the process. This will reboot your computer.
