Labtec LCS 1024 Computer Speakers Logo
Posted on Dec 04, 2008
Do not know how connect lcs 1024 speakers
Need a owners manual threw mind away dont remember how to hook up to cpu
4 Related Answers
Open SKy
Carlos L. Burgos
  • 620 Answers
  • Posted on Feb 15, 2008
SOURCE: Schematics
Dclf1
Good day!
First things first:
1) you only can find those schematics on
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
but have to call or email support.
hope they can send the info.
Open Sky
A
Anonymous
  • Posted on Mar 29, 2008
SOURCE: Labtec LCS 1024
Do you have any schematic of Labtec 1025 with wiring conection? Thank you for your response it does help me alot
Anonymous
  • 4 Answers
  • Posted on Feb 08, 2009
SOURCE: labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
Anonymous
  • 51 Answers
  • Posted on Feb 17, 2009
SOURCE: installing Labtec LCS 800 speakers
1 wire goes between the 2 speakers
1 wire goes from the speaker with 2 jacks in it to the computer, the back of the computer should have a green port to plug in the cable to
1 wire is the power
this is a guess without seeing your setup
What's the part number for the operational amplifier ,DC 15dc of LCS 1024
why not photo the IC, and show that.
for 10x better answers.
not told what car is came out of or what the OBJECT did. (PCM/ECU/BCM ,etc?) <<< vast on cars/trucks\
many PCB or Modules the ICs are some or all , contract parts
and the number on top is secret contract Part number.
ahhhhhh it is not a CAR at all it is
LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS moving you now to computers stuff
What's the part number on the amplifier board for LCS 1024 LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS
moved your double posts out of CARS to Computers.
AND THE MAKER SELLS NO PARTS FOR IT.
IT IS A CHEAP THROW AWAY DESIGN
BUT IF LUCKY USED BOARDS SEEN ON FLEABAY.
I do not have manual or driver, how do I install Labtec LCS 1014?
mcdevito75 here, Your computer already has the Audio installed, you just need the speakers themselves hoked up. If your a bit handy simply obseve the cable ends of the cables supplied with the speakers, plug the cables into the speakers, one cable should connect both speakers together for stereo and a 3rd cable should connect 1 speaker with the back of your computer, there will be a symbol for speaker on the back of your computer. Do not force and cables, as they should fit with a gentle push into place on the speakers and computer. Visit your local Radio Shack or Staples for more info.
2answers
I just hooked up my Labtec LCS-2420 speakers to my new computer and can't get any sound out of them. I can get the cheap ones that came with the computer to work, but not the Labtec. I hooked them up to...
if its a 6 channel connection its a little tricky try reconnecting your speakers that has a green connections. try playing a music while troubleshooting the connection...hope this helps..ITTech7574
1helpful
2answers
No wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
1helpful
Installing Labtec LCS 800 speakers
1 wire is the power
2answers
Labtec LCS 1024
I don't have a wiring diagram for you but can tell you this as standards apply.
Red is always the positive (+) terminal and black the negative, ground, (-) terminal. FYI-though people use the term ground it is not correct.
Another thing you should know is red and black are relative. Inother words, when red to red and black to black it will cause an outward motion of the speaker. If you happen to reverse them, red to black, it just causes an inward motion of the speaker. Sometimes this is refered to as the "phasing" of the speaker.
Speakers are usually marked at their connection points with a red dot or a (+) for the positve and a black dot or (-) for the "negative" side.
So there's nothing to worry about if this happens anyway except:
if you were to go red-black on one speaker, and red-red on the other. This will cause the speakers to be in series which normally wouldn't hurt things, but make sure it's not done just in case you amp section cannot tolerate this condition.
Hope this helps.
Jeff
1helpful
Schematics
Dclf1
Good day!
First things first:
Open Sky
Top Labtec Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
