The caller on the other end usually have problems hearing me. I have read it is about the eco mode not permitting the phone use the needed power to work well.
You cannot turn off the ECO mode manually.
Intelligent ECO mode (select models)
Power consumption is automatically reduced when the handset is close to the base unit for extended talk time.
Battery life on Talk is up to 13 hours when in ECO mode.
https://panasonic.ca/english/telecom/telephones/features.asp#eco
SOURCE: This is really silly, but
HOLD DOWN the "M" key which is the "*" key in the bottom left for 3 seconds until you hear a beep. Repeat if you want mute again.
Jack
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
SOURCE: My phone is a panasonic
Try unplugging all units from the AC outlets as well as the phone connection. Leave disconnected for a few minutes. Re-connect all units and try calling out or have someone call in. this should correct the problem.
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
