There is a wire that I think came a loose and should be connected to something?? but I don't know where. My fridges freezes everything and I think this wire is the culprit.
SOURCE: I just bought a used
Probably low on gas.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Which wires go wear when installing a new
In a mini fridge there are only two wires to the thermostat. I really does not matter which wire goes were because all it does is turn it off and on. Sea Breeze
SOURCE: Haier RRTG21PAAW
Well, your answer would seem to be simple...but in truth it could be many a issue. Just because the light is on does't mean anybodys home. Basic, (a) the cold control (dial in fresh food section that usually shows the word "off" at the warmest point on the dial) try turning it up to its coldest. Sometimes it might not reset after it turns off when it senses its cold. Also try tapping in the area of the control. If the freezer fan is not operating this or the defrost control could be the issue. (b) The defrost timer (mechanical or electronic) might have fail to advance out of defrost. Advanced items, (a) The compressor and or compressor relay and overload might be bad. (b) The evaporator fan is not operating (controled by the cold control circuit). (c) the condenser fan failed, which will cause the compressor to fail or shut down due to overheating. (the condenser fan is controled through the compressor circuit. These advanced items would need a multimeter and a understanding of circuit diagrams.
Ric
SOURCE: My fridge keeps freezing everything
To raise the temperature of the refrigerator you set it to a higher number.
Hi Charlene,
Open the freezer and see if it needs a good defrosting. I know you may think you bought a Frost free Fridge, but if something goes wrong with the forst free system, It can frost up. If it is Frosted , Turn the Fridge off and use a hair dryer for about 30 minutes to melt all the fost and dry up the frezzer compartment, It is imprtant to dry u the Freezer compartment. Hope this helps you.
