When I turn on the dw and fill w soap, when the dw stops I open the door and half the soap is still in the reservoir and some is just dripping down inside the unit. Only half the dishes even look clean. Nothing too tall is put inside, so the spin bar is definatelt spinning still. What can I do?
SOURCE: frigidaire dishwasher...
It is very possible that something could be obstructing the main pump. But, first. Does your dishwasher fill with enough water? When full, the water level should fill to just below the heating element. You can check this by waiting for the fill cycle to stop and the normal wash cycle to begin. Open the door and check the water level. If your dishwasher isn't getting enough water, you could have a bad fill valve, or the inlet water line could be kinked. If this isn't the case, then suspect that you might have a clogged pump. Food particles such as popcorn kernels, orange or lemon seeds, small chicken bones and glass are notorious for getting into the pump screen area and obstructing the water flow (some of the other items I have found are labels off jars, bottle top seals, twist ties, rib bones, hair scrunchies, and yes - even band-aids!). Even though some dishwasher manufacturers advertise some amazing capabilities of their dishwashers, you still need to scrape your dishes of all food particles as much as possible. This does not mean you have to pre-wash prior to loading them. Anything that doesn't get dissolved by the wash cycle and detergent will end up sitting in the pump well. If the pump isn't able to pump enough water, your dishwasher will fill normally, but the spray arms will not turn, detergent does not dissolve and your dishes will not come clean. To get to the pump, you need to remove the lower spray arm and the coarse screen (located directly under the lower spray arm). The pump well should be located under the coarse screen. Look for anything that may restricting the water flow. I hope this helps and it's easy fix for you.
SOURCE: Garbage Disposal backing up in dishwasher
Most dishwasher have a check valve at the pump to prevent water from backing into the dishwasher. If the pump is electric there is a rubber flat that may be gone or not working properly. If that is the case you need to replace the pump. If the pump is part of the motor assembly then the pump and motor will need to be replaced. One other thing to make sure of is that you have the drain hose looped to the top od the dishwasher and then to the disposal conection. Its called a drain loop and all dishwashers should have it. Good Luck
SOURCE: Frigidaire dishwasher sounds funny and arms turn slowly
worn internal parts repare or replace
SOURCE: Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
SOURCE: Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
