When i try to turn my camera on it makes the starting sound, the lens extends and the screen shows the "canon" image and then turns black. I cannot view anything on my memory card, it wont connect to the software on the computer. I have tried erasing everything on the memory card, uninstalling and reinstalling software and just charging the battery. Dont know what to do next.
SOURCE: Canon Powershot A510 - black screen
well giving it a tap/thump it might have a dry joint ....
SOURCE: My Canon PowerShot SD1000 shoots completely black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
SOURCE: I have a cannon sd780 camera. When i try to shoot
The disc may be corrupted, try formatting the it.
Testimonial: "good suggestion"
SOURCE: Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
SOURCE: Canon powershot SD780 is camera. Camera shows the
There's really no way to restart it if there's a physical problem with the lens. Try to power it on again but if that doesn't reset it, the camera needs to be serviced. A great site for help with these is: camerasandparts.com They just specialize in service for the Canon Powershots and nothing else, they are fantastic if you need help with one of these problems. Try them, your exact SD780 lens error restart camera problem is right on the site for the SD780. Good luck, that's the place for help with a powershot, it just sucks that it happened while you are on vacation.
