I installed the ATI vga driver Radeon 7500 on my laptop N610c and noticed that when windows boots and is about showing the welcome screen, my lcd goes blank even though the system is still on.
what could be the cause...Pls help!!!
Thanks
Big E
i have no vga driver of my laptop evo n610c compaq plz give me this driver
thank you
Plz i want compaq Evo N610c vga driver
HI
GOTO MENU THEN GO TO SYSTEM INFORMATION AND PRESS OKAY THEN POINT
REMOTE AT BOX AND TYPE 1004 THIS SHOULD TAKE YOU INTO A NEW MENU GO TO
NAGRAVISION AND PRESS OKAY NOW USE THE LEFT RIGHT BUTTONS TO SELECT
EITHER NTL-TELEWEST-C&W USE THE UP DOWN BUTTONS TO GO TO THE CODE
AND CHANGE IT THE LETTERS A,B,C,D,E,F SHOULD BE COLOUR CODED IF NOT USE
PAUSE TO ENTER A AUDIO TO ENTER B RED FOR C GREEN FOR D YELLOW FOR E
BLUE FOR F AND USE THE NUMBERS REQUIRED TO MAKE THE CODE THEN PRESS
OKAY THIS SHOULD STORE THE CODE THEN EXIT BACK TO THE TV IF THE CODE
DOES NOT WORK TRY ANOTHER HOPE THIS HELPS.
thank you
I need vga driver for my compaq N610c
I need VGA driver for Compaq Evo n610
