Question about Mustek PVR-H140 Digital Media Player
Frozen hi, iv a double problem. the inside of the input for charging has snapped off sumhow(?) and my screen is stuck on initialise so i dont no if its worth getting repaired! iv tried d/l the prog recommended but cant transfer it onto the machine. thanks for your time
1) you can charge off the usb port
2) pv-h140 has basically 3 parts
1- 40 gb hard drive (ususally a fitjitsu)
2- a battery pack (similar to the cordless phone)
3- the lcd and the pvr panel
when it hung on initialize; this means the hard drive crashed or the file is corrupt. if you drop it; you can reseat the cables and sometimes that helps.
Posted on Dec 10, 2008
SOURCE:
Install myanmar font
How to install and use Zawgyi Myanmar Font
  1. Download Zawgyi Myanmar font and keyboard driver here.
  2. Find and Unzip the downloaded file
  3. If you know how to unzip the zipped file, skipped to Step 4.. Otherwise read on.
    1. How to unzip downloaded file
i.You need to have file compression software to zip or unzip the file.
ii.If you have winzip or similar software, you can use it to unzip
iii.Otherwise download z-zip application here
iv.Double click on 7z444.exe
v.Click Install
vi.Click Finish
vii.Right click on the downloaded file
viii.Select 7-Zip, then select "Extrace to"ZawGyiFont\" and it will create a "ZawGyiFont" folder.
  1. Installing ZawGyi Myanmar Font
i.Inside the folder, you will see the following.
ii.Click "Start" then "Setting" and select "Control Panel"
iii.Double click on "Font" folder.
iv.Copy the "Zawgyi-One-20051130.ttf" file and paste it to the "Font" folder above and finish the font installation.
  1. Keyboard Driver Installation
    1. Open the "ZawgyiKb_installer_I" folder under "ZawGyiFont"Folder
  1. Double Click "ZawgyiKb.msi" file and installation is completed.
  1. You sill need to set up Zawgyi Myanmar Keyboard driver to type using Zawgyi Myanmar font.
  1. ZawGyi Myanmar keyboard setup
    1. For Windows 2000
i.In Control Panel, double click on "Regional Options"
ii.Click on "Input Locales" tab and click "Add"
iii.In the Keyboard Layout/IME: drop down menu, select "Zawgyi Myanmar Unicode Keyboard" and Click "Ok" then Click "OK" on "Regional Options" window
iv.Keyboard installation completed.
  1. Windows XP
i.Open "Regional and Language Options" in the Control Panel
ii.Click on "languages" Tab and click "Details"
iii.Click "Add"
iv.Check "Keyboard layout/IME: check mark and select "Zawgyi Myanmar Unicode Keyboard" from the drop down list and press "Ok"
v.Press "Ok" on "Text Services and Input Languages" window and press "Ok" on Regional and language Options" window
  1. Testing Zawgyi Myanmar Font
    1. Open a blank word document.
    2. Select Zawgyi-One in "Font" drop down list.
    3. Type some words, and try Ctrl+Shift OR Alt+Shift to toggle between Burmese and English. (NOTE: Either Ctrl+Shift OR Alt+Shift will work as toggle mode. You can set up this key combo as the way you want by pressing "Change Key Sequence" button in Input Locales
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Apr 15, 2014 | Lenovo Computers & Internet
Once i charge the kurio the screen comes on with the smiley face and thats it
Sounds like the "frozen screen" issue. Hold the on/off button of the tablet well also pressing the Volume+. This should FIX it and unfreeze the screen.
LindaSView
Apr 04, 2014 | Techno Source Kurio Kids Tablet With...
Coby mp3 is frozen
Hi.
Try to hold the turn on button for one minute.
If its still froze, try to charge it or connect it to the PC to see if there's any difference on the screen.
Aug 01, 2010 | Coby MP620 MP3 Player
Same problem as funkgruven. Stuck on G1 logo screen. Will not power on or off. Can get to triangle screen with exclamation point but any action will return it to G1 logo screen.
well when this happen than you screen is frozen so now you have to wait until the battery die.I suggest you dont charge it let it die. Than you get a new chance.
Mar 29, 2010 | HTC G1
Its frozen at the screen with a square with circles inside! help!
Call T-mobile, they will send you a replacement phone via mail. Just tell them the problem, and they will issue a replacement as long as there is no physical damage nor liquid damage, for free, minus shipping.
Jul 31, 2009 | Sharp Cell Phones
Technics sa dv280, input selection
You can try starting the music on your computer before trying to change the input on the receiver, maybe it needs to recognize some input before it will change if this doesn't help double check your connections & settings ?
Jun 25, 2009 | Audio Players & Recorders
LG DR4812W DVD RECORDER DISC INITIALISE
hi!we have read your problem.please dont worry, every problem hasa solution.all you have to do is buy a dvd lens cleaner and clean the4 dvd lens since dust particles on lens will delay the processes.but make sure you are not using detergents or plain water to clean it and never touch the lens with bare hands hope your problem is tackled.have a nice day.
May 23, 2009 | LG DR787T DVD Recorder
Frozen Screen
one ofthe keys on your keybord is stucked up try to check pls
cheers
Oct 29, 2008 | Lenovo 3000 N100 Notebook
Frozen screen
you should hit the reset button and that should do the trick and always make sure it's charged
Sep 13, 2008 | Sony NWZ-S616FRED Digital Media Player
Mustek PVR-H140 Digital Media Player Logo
Top Mustek Audio Players & Recorders Experts
John Elliott
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
