Plantronics - Bluetooth Headset Plus Base & Headset Logo
Posted on Dec 04, 2008
Plantronics 520 will not pair
My Plantronic 520 was paired with my previous blackberry, which died. Now I'm trying to pair with my new blackberry and it won't pair. I cannot disable pairing with my previous blackberry since it won't even turn on... How can I get it to pair now?
  • Anonymous Jan 24, 2009
    MY plantronics 520 was paired with my casio boulder now i want to pair it with a motorola and I dont know how to do it.
  • BlueHorizons May 14, 2009
    My Plantronics 520 was previously paired with my old Iphone and I want to pair it with my new Iphone.  It won't pair with my new one. Help.  The instructions above don't seem to work
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1757
Points
27
"Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue."
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Nov 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
3901
Points
33
The fact that the previous device is disabled should not matter.
  1. Turn on both the phone and the headset
  2. To put the headset into pairing mode, at the same time press the Call Control button (side of the headset) AND the volume button marked "+". When the status indicator light flashes between blue and red, you are in pairing mode.
  3. Now use your phones menu to search for bluetooth devices, you should see it say "PLT 520" on the screen. Note, this can take up to 2 minutes.
  4. When it asks for the passkey, enter "0000" (zeros). When the light on the headset turns blue you are successful.
  5. If this fails, try again
  6. If this fails again...reset the headset. To reset, do a long press of the MUTE and volume down buttons simultaneously for about 3 seconds, then try the procedure again.
Anonymous
Level 1:
  • Posted on Oct 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1757
Points
6
This works; the secret is to continue holding the silver button after you hear the beep for the full ten seconds.
Tara
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 01, 2013
Tara
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1831
Points
I just finally figured out that you need turn on the bluetooth on your phone so it is searching for a device. Then you need to hold the volume/power button down until it shuts off, then hold the button again to turn it back on and keep holding the button down until you see the red and blue flashing back and forth. At that point, your phone will find your device and you can enter the password which is usually 0000.
Am trying to pair plantronics voyager 520 with LG tracfone it does not work with 0000
According to the user manual for the trac phones, you pair it up like you would any other bluetooth device.
Plantronics 520 Bluetooth User's Guide
Good luck from Headsets Direct!
Cannot get plantronic device to pair with my blackberry
Try turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and select the headset then try reconnecting the two again.
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
3helpful
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
Feb 10, 2010 • Cell Phones
1helpful
Need to repair my plantronic 230 to new phone
you should be able to pair it to at least three devices passcode is 0000
How do I put my used Plantronics Voyager 521 back in pairing mode My new LG CE110 can't find it
I have recently purchased a Blackberry World. I would like to connect my Plantronics with this Blackberry but, I have forgotten how to put it in pairing mode. Please assist me on how to do this.
Thank you
I am trying to pair my 520 to a new phone.
The default password for Plantronics is 0000
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
