Kenmore ultra wash dishwasher model number 665.158.5090
the only way you can tell if the upper rack is not getting enough water is to turn a glass right side up in each corner. then run for 2 minutes and see if there is water in each cup.
if you still dont get water, then you have checked the pump, the only thing left is that you are not getting enough water into the unit.
start the d/w at a normal cycle, let it fill and go into the wash cycle, takes about 3 minutes, then check to see if the water level is just below the heating element. if so then it has to be the wash pump being plugged.
if not enough water then you should change the water inlet valve. some times they do get plugged but also make sure you are getting full water pressure to the unit as that could cause not enough water into unit. the faucet under sink could be at fault i have seen valve work but not let enough water in, so dont be surprised if you need a new valve.
When new the water level was visible at the bottom of the front window when filled and water could be seen sloshing around as the cycle ran. Now, while the clothes are wet I don't see any water sloshing and the washer does not seem to get clothes as clean as it used to.
