My odometer gages and fuel gages are going nuts... and sometimes this causes my rear brake lights not to work. What is causing this? HELP!!
SOURCE: Instrument cluster failure causes fuse #29 to blow.
ok it could be quite simple
lets look at wrong size fuse
example 15 and you need a 25 fuse
also if you did any work on vehicle its quite possible that you grounded something out wrong retrace your work and fix accordingly
bad cluster relay is another problem that would cause these problems
SOURCE: what causes both brake and
Many cars have the same fuse for turn signal and brake lights. Check that fuse for a start.
SOURCE: 1989 Ford ranger rear antilock light on rear brakes lock up
metal particles on the trigger wheel sensor of the rear differential case, this causes a loose of signal and the light to come on. also a broken tooth on the trigger wheel inside the diff can cause this or a dirty/corroded connection to the sensor from water intrusion.
SOURCE: rear wiper stopped working
my 2004 expedition had same problem, if you take apart the shaft that goes thru the glass it will be full of dirt, clean ,lubricate and reinstall, you may have to replace the O-ring on the shaft. a 20 minute job, very easy fix
SOURCE: what causes the brakes to go out
it might be your master cylinder..."my brakes go out" is not the best description. if the pedal feels very soft, or goes all the way to the floor, then its probably the master cylinder. also, if you just had break work done, then its possible that not all the air go blead out of the system. if the breaks are hard to push, then your break booster may have a leak..
cheers
The IPC detects a loss of class 2 communications with the PCM.
Fuel Gage
When the fuel level is less than 14% (84ohms), the low fuel indicator illuminates.
Speedometer
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
The PCM detects a malfunction in the fuel level sensor circuit.
Odometer
The IPC contains a season odometer and a trip odometer. Momentarily press the trip select/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip select/reset switch for greater than 1.5 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the IPC. The IPC calculates the mileage based on the vehicle speed information from the PCM. The odometer will display 'error' if an internal IPC memory failure is detected.
PRNDL Display
The IPC displays the selected gear position as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the gear position. The PRNDL display shall flash all gear positions if:
The PCM detects a malfunction in the transmission range switch circuit.
The IPC displays the vehicle speed based on the information from the PCM. The PCM converts the data from the vehicle speed sensor to a 4000 pulses per mile signal. The IPC uses the vehicle speed signal circuit from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 mph (0 kph) if a malfunction in the vehicle speed sensor circuit exists.
Tachometer
The IPC displays the engine speed as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine speed. The tachometer will default to 0 rpm if:
The PCM detects a malfunction in the engine speed sensor circuit.
The IPC detects a loss of serial data communications from the BCM.
Fuel Gage
When the fuel level is less than 14 percent, the low fuel indicator illuminates.
The instrument panel cluster (IPC) displays the fuel level as determined by the powertrain control module (PCM) or the engine control module (ECM). The IPC receives a serial data message from the body control module (BCM) indicating the fuel level. The fuel gage defaults to E (empty) if:
The PCM/ECM detects a malfunction in the fuel level sensor circuit.
Odometer
The instrument panel cluster (IPC) contains a season odometer and a trip odometer. Momentarily press the trip/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip/reset switch for greater than 2 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The odometer is calculated and stored electronically in the body control module (BCM). The BCM uses the vehicle speed information from the powertrain control module (PCM) to calculate the odometer. The odometer displays 'error' if an internal IPC memory failure is detected. The IPC stores a backup copy of the odometer value incase the IPC stops receiving a valid odometer value from the BCM.
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed based on the information from the ECM/PCM. The IPC receives the vehicle speed information from the BCM via the serial data circuit. The speedometer defaults to 0 kmh (0 mph) when the following occurs:
The powertrain control module (PCM) or the engine control module (ECM) detects a malfunction in the vehicle speed sensor circuit.
The IPC detects a loss of serial data communication from the BCM.
the fuses have already been checked. I would have to slap the dash board to get them to stop going nuts. the rpm gage finally just stopped working its all the way over to the right. and now the mph gage and fuel gage is acting up. its really ticking me off. I dont know if all this has anything to do with the brake lights to not work sometimes...
