Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
Anonymous Posted on Jun 23, 2012
Husqvarn lgt2654 wont pull
Transaxle broke, replace both sides, and new drive belt, will mow fine, slower than normal does not want to pull up even the slightest incline
  • Anonymous Jun 25, 2012
    ok we'll check that, another question when my husband put transmission oil back in after we changed the axle, he used 5w30. i notice yesterday when mowing when i first started it had normal pull ability. after i mowed for awhile i could tell it started losing its pull and started going slow. should we maybe have used 5w50
vichall67
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jun 23, 2012
vichall67
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
6
Helped
10741
Points
20
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Testimonial: "thanks for the info. we had the schematic belt is on correctly, all he gears in the transmission looked really godd and clean no metal fragments when we changed the axle. any other ideas, thanks"
  • vichall67 Jun 25, 2012
    Check the idler pulleys for the drive as one of them might be faulty.
5 Related Answers
Anonymous
  • 2559 Answers
  • Posted on May 10, 2009
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Anonymous
  • 95 Answers
  • Posted on Jul 30, 2009
SOURCE: blades became disengaged -- won't engage
Sometimes the belt can jump off one pulley and cause the problem,follow the belt around all the pulleys and see if it came off one.there may be a belt loosening lever on the lh side of the mower deck, if so unlock it and reroute the belt around the pulley. If you need to replace the belt the manual has a good description on how to do it and should take 30 min with only a couple of tools.
Anonymous
  • Posted on Jul 28, 2009
SOURCE: placing the belt on LGT2654
Does anyone have a layout on how the belt goes on the 2554
Anonymous
  • 2702 Answers
  • Posted on Aug 01, 2010
SOURCE: husqvarna lgt2654 96045000700 ran out of oil
check deck if free to turn and cutter blads are sharp also check the air filter is clear
Reggie Walters
  • 5 Answers
  • Posted on Sep 12, 2010
SOURCE: The LGT2654 riding mower will
check the drive belt. Deck belt has nothing to do with tractor motion.
Craftsman model #247.288842 Running slower and slower
NOT IF THEY ARE NOT WORN OUT DECK IS SEPERATE BELT
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Tractor won't move
drive belt broke if transaxle is not turning does clutch pedal feel loose ?
Lgt 2654 runs fine. But when I engage the mower it pulls the engine down alot and when I start to mow it really pulls it down and it hammers. All the pulleys and idlers are free.
Sounds like the mower belt may not be routed correctly around the pulleys or may be running on the wrong side of a belt guard. Also check under the deck to make sure there are no obstructions to the turning of the blade or bent blades....you did not state where the hammering was coming from ( engine or deck ) I can only assume that it is on the deck....so these are the things I would check. Also check the tightness of the bolt on the main pulley sheave (the pulley on the bottom of the engine that drives the belt. the bolt is in the center hole of the pulley) if it is loose it can cause misalignment of the belt and juddering of the deck. If the bolt is tight, remove the belt from the engine pulley sheave and start the engine and look to see that the crankshaft is not bent causing the pulley to wobble....worst case scenario....will require new engine...hope this helps... ;-D
4helpful
While mowing it started 'jerking' going forward (John Deere RX75)
if this is a MTD rider, (troybilt, yard man, yardmachine,. bolens, cub, etc) the transmission is likely a single gear forward and reverse with a variable speed pulley mechanism with two transmission belts, these trans are prone to failures of the gear clutch which is a dog style clutch with some small teeth that engage the gear plates, these teeth can wear off on one side resulting in the popping or chattering while retaining full functionality for the other direction, this is the gear set inside the transaxle and is usually an indicator of significant wear inside the axle housing itself, usually entire transaxle replacement is the most common and effective repair solution.
Jun 04, 2010 • Garden
6helpful
After a couple passes tractor will not climb hill. Gets slower then will just stop on hill. The hill is approx. 35 degree incline. I mow up the hill, then back down and mow up again, continuing to mow...
To me it sounds like the hydro unit has developed internal leaks and the pressure lowers as the oil thins from heat.These trans axles are usually replaced as an unit but some can actually be repaired.call the dealer to see if you can get parts or whether you need to replace the whole thing.I assume you have already tried a new drive belt,tensioner ect. and if so you are down to the trans axle.You may buy some time buy getting rid of the low viscosity oil in the rear end and go to regular hydraulic oil.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
