SOURCE: when cold in morning starts and runs fine once hot
If its the 3.0 diesel you have a glowplug fault .
May just be the 40 amp one under the hood or one or more glowplugs have burnt out they can be tested in place by using the ohms on a multimeter - O reading duff plug - 0.8 - 1.0 ok.
Also check for 12v on the plugs as the relays can go too .
SOURCE: We have a 2002 Mercedes Sprinter LWB 313 CDI
check air filter, fuel filter, and spark plugs in that order. make sure you check all fluid levels too.
SOURCE: how to change a fuel filter in a sprinter 313 cdi
I have trouble starting my 313 cdi van. Its a 2003 model. When I spray ether into the air filter, it starts. I know the glow plugs need replacing, but even on warm days it wont start. Any ideas?
SOURCE: 2003 Mercedes-benz Sprinter cdi 316 cuts out and doesn't start
Hi, My thoughts exactly ( fuel leak). Is this a deisel or gas engine?
In both cases be very careful with lights or cigarettes.
You can smell it when you get out of car in a garage or stall.
Good luck.
