SOURCE: my nokia E51 is locked can u tell a master code to unlock
First of all try 12345 (the standard one)
If this is not working try using this software: NSS to read the phone code:
http://www.b-phreaks.co.uk/software.htm
You should see the lock code when you use the softare.
If not, you might consider formatting your phone.
Switch it off, and : Pressing the following key at the same time: 3 * green button, switch it back on - the three keys must be pressed and held - then press the power button still holding the 3 keys.
The best places to find out what to do:
http://www.allaboutsymbian.com/
http://www.symbian-freak.com/
SOURCE: i have locked my nokia 2626 security code please provide me with
please tell me security code nokia 2626, which serial no. is 353083024115650.at present time i use BSNL.
SOURCE: I forgot my lock code for my nokia 5230. Please
You can see your default lock code in the booklet provided with your phone when you brought it. Just go through that booklet and search the lock code.. it may probably be 12345
