Question about King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P
I have a king kutter brush hog. the bolts are all loose on the gear box.. I have to take off the stump jumber to tighten them. Is the caslte nut on the shaft revers thread?
This is a 5 foot king kutter brush hog
3 Suggested Answers
SOURCE:
  • 496 Answers
SOURCE: just bought a 6 ft king kutter brush hog - no
I took a stab at this... I hope this is what you are looking for:
http://www.kingkutter.com/downloads/manRKRK.pdf
Posted on Aug 31, 2009
mister_b_65
  • 74 Answers
SOURCE: how much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
Posted on Apr 09, 2010
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
Gear box filler plug
glue or weld the head of a bolt to it.then use two nuts on the bolt tighten both of them now a ring spanner on the first nut as is held by the second nut.
Dec 16, 2013 | 2005 Nissan Sentra
My brush hog is leaking from the seal, bolts were loose
they seal was most likely damaged when moving around reseal the housing and replace the seal
Aug 11, 2012 | Garden
How much gear oil for gear box and gear case
most gear boxes have a bottom drain and a side fill plug , you fill until the oil runs
out of the top plug
Oct 18, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
How do you remove a pulley from a spindle unit to replace the bolts holding it to the deck.
First remove the nut on top of the pulley using a 1 1/16 in. wrench or socket. Then you will need to pry the pulley of the shaft using two pry bars. A bit of force may be required. It will kind of pop off when it does finally break loose. Be careful not to lose the half moon key that will still be in the slot on the shaft.
Aug 18, 2010 | King Kutter Pull Type Rotary Kutter 72in....
How much gear oil 72'' tiller
Apr 09, 2010 | King Kutter II Gear Driven Rotary Tiller...
Hi - recently bought a new KingKutter 4ft bush
go to kingkutter.com and download the manual.
hatter1
May 15, 2009 | King Kutter Pull Type Rotary Kutter 72in....
King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P Logo
753 people viewed this question
Top King Kutter Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a King Kutter Tool and Hardware - Other Expert? Answer questions, earn points and help others
