Control Lock Light is On and will not turn off by holding the heated dry button for 3 seconds as manual states. Also tried turning power off, via circuit board, for various lengths of time (up to 30 minutes) hoping for a reset, but it did not. Is there an alternative way to turn the control lock off, or a way to reset the controls to original condition? Thanks
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
SOURCE: "Light Dry" light flashes 5 times & odd light displayed
maytag website...all the help youll need
SOURCE: Our dishwasher's lock indicator won't turn off,
Try holding the button down for longer say 5 seconds. When you push the button and hold it the little green light should blink. I would disconnect the power for longer..try 20 minutes. If that does not work then remove the inner panel and disconnect the control panel connector from the control box then plug it back in...see if that clears the locked control. If it continues to have a problem then you may need to replace the control panel.
SOURCE: How do you unlock control
Try pressing and holding Heated Dry Button for about five seconds. If it's locked that should onlock it. Hope that is your problem.
Hello &
Welcome to FixYa
You can press
and hold the RINSE ONLY/AIR DRY/HEATED DRY button for 20 seconds to reset the
control. Please get back to me if you have any other questions.
Kevin
