SOURCE: phone dead after opening java executor
I had the same problem with a k800i, i emailed sony ericsson and they told me what to try and it worked however you do lose everything you had stored on your phone. I believe this will work with most if not all sony ericsson phones. You need to update your phone, here's what to do;
1.Go to www.sonyericsson.com/support
2.Select UK
3.Select your model of handset
4.Click on Sony Ericsson Update Service
5.Click the link, and then click Run or Save.
6.Let the Sony Ericsson Update Service install.
Once
you have installed the Sony Ericsson Update Service you will need to
launch it. Once it opens simply follow the instructions that you will
see on screen. The update should then begin.
SOURCE: Sony Ericsson W350i - replacement hinged keypad cover
While this may not be typically, I just talked with Sony Ericsson and they are sending me a new flip cover at no charge. I should receive it within 3-5 business days.
SOURCE: puk code for sony ericsson w350i
call your mobile service customer care number and ask your puk code from them...they will ask yourr last 4digit sim card number...give that number to them...they will give puk code ...use that code and continue your operation
